crank sensor question
Old Jan 20, 2010 | 06:42 PM
bluebomber2500's Avatar
bluebomber2500
Default crank sensor question
so, i know this could be a stupid question if there ever was one. i have a 97 ram with the 5.9 v-8. im putting a new motor in it, and i was wondering what the crank sensor plugs into and where that plug is. And by the way, if you have any other tips on putting a motor in, and wiring and vacuum line info, that would be appreciated.
Thanks. Brian
Old Jan 20, 2010 | 06:47 PM
95RAM360's Avatar
95RAM360
for the wiring and vacuum line info get a haynes repair manual...ive re-done my vacuum lines, if need be i can take pics of step by step where what goes where if you need me to.
dont know crank sensor location off the top of my head, but i keep thinking its on the tranny
Old Jan 20, 2010 | 07:27 PM
yakkier's Avatar
yakkier
top left of the tranny about 6 inches from the belhousing, it's going to be a b!tch to get at with out dropping the rear of the tranny
Old Jan 20, 2010 | 07:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You looking for where the CPS goes or the other end of the electrical connector? And the only other advice I have is, next time label everything and take pictures.
Old Jan 21, 2010 | 12:33 PM
bluebomber2500
i got the sensor in, i just cant figure out where it plugs in at
Old Jan 21, 2010 | 05:46 PM
quackaddict's Avatar
quackaddict
Boss Man if you could do that it would make several peoples lifes alot easier..............especially me, I found a broke vacuum line and no clue where it cam from.
Would be a good FAQ.
Also my CPS is attached to the back of the block and goes between the belhousing and engine, there is a cutout in the bellhousing for it.
