Amazing
Old Jan 22, 2010 | 06:43 AM
95RAM360's Avatar
95RAM360
yingchu777, what tires are you running?
what problems were goin on before?
Old Jan 22, 2010 | 08:12 AM
yingchu777's Avatar
yingchu777
Cool
Originally Posted by dakotas ram
is this not about the other probs youve been having?
Yes, it is about the other problems. That's the amazing point, rotating tires and increasing air pressure in two front tires corrected everything.
Old Jan 22, 2010 | 08:31 AM
yingchu777's Avatar
yingchu777
Cool
Originally Posted by meanwhitemopar
if this truck is so nice... lets see it... im curious now...
and i check my tire pressures everyother day... but i roll around on 37's, so its a bit more important... at +300 bucks a tire... and i rotate like every two weeks, have a warrentee on my alignment, so i go back after i rotate tires and have them check it like every two weeks for free..
I'll have to pay attention to the Michelins like you do. Before I ran Firestones that came with truck for eight years.
The sidewalls say 44PSI. How high can you go before the EXPLODE?
Old Jan 22, 2010 | 08:34 AM
yingchu777's Avatar
yingchu777
Cool
Michelins have about 15 miles on them, figured they were best on the road. No?
Old Jan 22, 2010 | 06:31 PM
Augiedoggy's Avatar
Augiedoggy
that much pressure in them might make them ride nice but it will likely wear them out in the center fast....
Old Jan 22, 2010 | 06:35 PM
yingchu777's Avatar
yingchu777
Cool
the sidewall says 44PSI
Old Jan 22, 2010 | 06:37 PM
yingchu777's Avatar
yingchu777
How many miles will they run and are they more dangerous at higher PSI?
Old Jan 22, 2010 | 09:04 PM
That1Dodge's Avatar
That1Dodge
Always go by sticker on the inside of the drivers door. The sidewall is the max PSI that the tires can run at. Anything more will cause premature tire wear.
Old Jan 22, 2010 | 10:19 PM
yingchu777's Avatar
yingchu777
Thank you
Old Jan 23, 2010 | 01:22 AM
nremtp723's Avatar
nremtp723
what is common tire pressure everyone is running in there tires?
