Leaf Spring Problem
Old Jan 23, 2010 | 06:21 PM
ms96ram1500's Avatar
ms96ram1500
Exclamation Leaf Spring Problem
I Rotated my tires today, I knew the leaf springs had a problem taking weight, anything 250-300 pounds the rear starts to sag, even with no weight in the back truck sits level, without a leveling kit, when I pulled the back wheels off the leafs looked flat, they had no curve to them at all. Anybody else have same problems, any solutions?
___________
Mopar Blue 1996 Dodge Ram 1500, 5.2, Intake, Flowmaster 40 Duals, 13 inch Slash cut Exhaust tips, Pro Comp Extreme All Terrains
Old Jan 23, 2010 | 06:24 PM
95RAM360's Avatar
95RAM360
they do tend to sag out...and the best advice i can giv you is replace the leaf springs.
Old Jan 23, 2010 | 06:31 PM
dhvaughan's Avatar
dhvaughan
either get a junk yard set or a new set (expensive). don't waste money re-arching the old ones. they just don't hold up.
Old Jan 23, 2010 | 06:37 PM
360mag45's Avatar
360mag45
get new ones or maybe a helper spring idk if that well do you any good
Old Jan 23, 2010 | 08:43 PM
yakkier's Avatar
yakkier
Might be a good idea to go find a set at the junkyard, and possibly do a add a leaf while your at it
