this one has me lost
Old Jan 24, 2010 | 05:55 PM
klklrl's Avatar
klklrl
Default this one has me lost
i just got a deal on a 99 ram but the headlights are not working. so far i have replaced the switch, the turning signal switch. the fuses and relays are good. but no headlights. all other lights are working fine. i am getting about 5 volts to the plug but the lights do not light. any ideas?
Old Jan 24, 2010 | 06:07 PM
yakkier's Avatar
yakkier
did u replace the bulbs ? stuipid question.
Old Jan 24, 2010 | 11:50 PM
dodgeramit_10's Avatar
dodgeramit_10
how about the ground wire or the headlight housing sometimes the wire will short and melt the housing and you wont have headlight
Old Jan 25, 2010 | 02:52 AM
iwhitne's Avatar
iwhitne
check the wiring as well.. are the sockets good and clean?
Old Jan 25, 2010 | 06:34 AM
95RAM360's Avatar
95RAM360
i had a similar lighting problem, and it all turned out to be 1 ground wire
Old Jan 25, 2010 | 10:45 AM
klklrl's Avatar
klklrl
Thanks folks
the bulbs are new.
the plugs have just been replaced.
I cut the ground from the plug and ground it independly from the rest but still no change. Is there others I should check? I am getting voltage at the plug but only around 5 volts.
Thanks
Old Jan 25, 2010 | 10:56 AM
yakkier's Avatar
yakkier
harness
