Epoxy in the Kegger
Old Jan 26, 2010 | 08:14 PM
  #21
dakotas ram's Avatar
dakotas ram
heres what the guy used
http://cgi.ebay.com/EPOXY-RESIN-STRU...item4837d22649
Originally Posted by DODGEPICKUP
its an medium viscosity epoxy resin made for adhesion to metals including aluminum . its a non-blushing epoxy so no wax will come to the surface after it cures . the marble dust is mixed to help with thermal cycling/thickening and is very fine mesh . it very flexiable so i have no worries about it breaking loose . oil/gasoline/anti-freeze has no effect on it and its able to withstand high temps . very very high impact resistence as well . the over the counter epoxy wont work . the faster it cures the more brittle epoxy gets like that 5min stuff . this epoxy took over 5 hours to start setting up 24hr to fully cure . very high performace stuff and is used in aerospace/military/naval applications . tensile strength of 9k at 250f. at 80f its over 15k .
Old Jan 26, 2010 | 08:53 PM
  #22
Silver_Dodge's Avatar
Silver_Dodge
The guy I talked to used what he called "Road and Bridge" epoxy. I have no idea of the specs on it, but that's what he used.
Old Jan 26, 2010 | 09:48 PM
  #23
dsertdog56's Avatar
dsertdog56
I know that one time Hughes engines was using epoxy to fill thier keggers, but you know, they've never told anyone what they used.
I like the idea of the filled intake for certain apps. Reducing the plenum area increases air velocity through the intake and allows a strong vacum signal and increased air velocity across the injector stream, possibly increasing atomization and improving combustion. A faster air flow can improve part throttle response.
Since air and gas aren't mixed in the plenum, (like a carbureted engine) the surfaces can remain smooth to further airflow.
The downfall might be that filling in too much area may start restricting the flow.
Old Jan 26, 2010 | 10:40 PM
  #24
Silver_Dodge
Ya, I heard Hughes was only using a small amount in the corners to to give the intake a more rounded surface on the inside.
  #25
cmckenna's Avatar
cmckenna
Originally Posted by dakotas ram
I work on aerospace and airborne products for the DoD, never heard of Max Bond. Judging by the packaging, it looks as though it's cheap stuff that I would only feel safe to use on a bar top. Do you have a TDS for it by any chance?
Just looked that up. That's a modeling epoxy used for sculptures and hole repairs as well as LIGHT-weight applications.
Here's an excerpt from their TDS: "It is also can be used as an adhesive for lightweight applications such as RC hobby craft" It's also a 90 shore D rating which is super hard which also means it's not flexible and is does not expand nor contract well at all which is the exact opposite of what you'd be looking for in an automotive application.
The other problem is the environmental testing is only rated for salt, freeze thaw and impact which are totally useless here. What you want to see is thermal cycling adhesion properties and sheer stress under thermal and random vibration profile at around 5-10 Gs RMS which is the equivalent to the auto industry application in question.
You want some really top notch epoxy, that is not even close. That stuff is cheap at 40/gallon.
Old Jan 26, 2010 | 10:41 PM
  #26
cmckenna's Avatar
cmckenna
Yes, according to Dave at Hughes, this is correct.
Old Jan 26, 2010 | 11:15 PM
  #27
Silver_Dodge
Ya seriously, think about the qualities an epoxy for this would need to have. I know my intake sits in temps as low as the negative teens in the winter time, and heats up to who knows what temp. All within minutes sometimes. Its heating and cooling properties would have to be close to aluminum so that it doesn't shear itself away from the mating surface it is attached to as it heats and cools. Plus, it would have to handle shaking and jaring from hitting potholes, wheeling, etc... This is the one main reason I could never get myself to even experiement with this idea. To much can go wrong if that epoxy should come loose.
Wonder what type Hughes is using?
Old Jan 27, 2010 | 01:08 AM
  #28
Weldor's Avatar
Weldor
I'd let a friend try it before I did.
Old Jan 27, 2010 | 01:38 AM
  #29
Silver_Dodge
Glad you're not my friend. lol
Old Jan 27, 2010 | 02:01 AM
  #30
1fast2liter's Avatar
1fast2liter
well the bridge epoxy would have to be close.. think how far roads and bridges move in heat and cold....
