Wheel back-spacing question
Old Jan 28, 2010 | 01:16 AM
  #21
silver06cummins's Avatar
silver06cummins
Originally Posted by olyelr
A 16x8 wheel with 4" of backspacing will stick out from the fenders. It will be right around 2" further out from that stock wheel.
Thanks for the info man!!
Old Jan 28, 2010 | 01:51 AM
  #22
011500Ram's Avatar
011500Ram
Originally Posted by silver06cummins
what kinda BS would I need to get so that they stick out a little past the fenders? 3 or 4?
3/4 inches is more than a little. That is a LOT. My front wheels sit almost 2 inches wider than my rear wheels, and I need fiberglass fenders. Take a look:
Old Jan 28, 2010 | 08:23 AM
  #23
silver06cummins
thats about what im looking for ^^^ what is the size and BS of your wheels and what size tires are you running? I would really like to get a 285/70 under mine hence the reason for a bigger backspacing so that they dont rub the control arms.
Old Jan 28, 2010 | 10:39 AM
  #24
olyelr's Avatar
olyelr
There is a very slim chance they will rub with the stock wheels anyway. Mine don't at all. Very minimal rub with 35x12.5's
Old Jan 28, 2010 | 12:40 PM
  #25
011500Ram's Avatar
011500Ram
My truck sits like that because I have spindles in the front. If you wanted your wheels to sit as far as my front wheels, you would have to buy wheels with ridiculous backspacing, and you will toast wheel bearings every 20k or so, with that much weight cantilevered off of the end of the hubs.
My wheels are 16x8's 4.5 BS, wrapped in 305 70 16's. If you were to buy those wheels, your tires would sit like my rear.
Old Jan 28, 2010 | 07:36 PM
  #26
silver06cummins
a co-worker has a 96 1500 with a 285/75 and at full lock his rub like cxrazy on the control arm, I dont want that to happen so thats why I was going to get a little different BS to cure that problem....
here are a few links...these are what im leaning towards
http://cgi.ebay.com/ebaymotors/4-NEW...sories?afsrc=1
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
I like the 2nd set best, but I'm still not certain
and here are the wheels I really like!!
what do ya'll think?
Thanks again
Brad
Old Jan 28, 2010 | 09:37 PM
  #27
olyelr's Avatar
olyelr
Huh. Mine don't rub at all. I also had a set if 305x70x17's (measured 34x12) that didn't rub at all either. I guess it just depends on the truck.
Old Jan 28, 2010 | 09:48 PM
  #28
silver06cummins
unless they are rubbing something else under the truck...? LOL.
so your tellin me that a 285/75 should work on the stockers? if thats the case I wont bother with wheels and save some cash!!
Old Jan 29, 2010 | 10:27 PM
  #29
olyelr's Avatar
olyelr
Yep. 285's should clear... but there are the select few who having rubbing issues.
If you planned on getting the same diameter wheels anyway, I would simply try it with the stockers. And then if it rubs a tinny bit and you cant stand it, THEN spend some coin on new wheels.
But, you should be good to go with the stockers.
Old Jan 29, 2010 | 10:57 PM
  #30
silver06cummins
woohooo I got the tires on today, 285/75's and they work like a champ!!
Looks like I wont be needing the wheels afterall, but the wife did say she didnt mind if I bought some, so why the hail not LOL....I'll get some pics tomorrow and post em up
THANKS FOR THE INFO GUYS!!!
