from a 318 to a 360
Old Jan 27, 2010 | 10:36 PM
318Ram4x4's Avatar
318Ram4x4
Default from a 318 to a 360
i got a 1995 dodge ram 1500, love the thing. oil pressure jumps up and down so i use lucas oil stabilizer, and pressure hasnt been jumpin around as much. Someone said use restore engine treatment and it worked better. anyway, if my motor blows, i was thinking about putting a 360 in it. is it a direct swap? do i have to swap anything else?
Old Jan 27, 2010 | 10:39 PM
Miami_Son's Avatar
Miami_Son
There are a ton of 318 to 360 swap threads already in here. A search should answer your questions.
Old Jan 27, 2010 | 10:48 PM
PurplDodge's Avatar
PurplDodge
What is the range that the PSI jumps around?
Old Jan 29, 2010 | 01:54 PM
318Ram4x4's Avatar
318Ram4x4
the psi starts a little over 40. as it warms up. without the lucas, it will go so low that the oil light will go on. i put the lucas in and never had that trouble.
