Vacuum line help
Old Jan 28, 2010 | 02:18 PM
quackaddict's Avatar
quackaddict
Default Vacuum line help
Ok I guess I am a re-tard and can't read the vacuum diagram, and I finally have a picture. Any idea where this line goes. It comes off the vacuum line that goes into the intake manifold on the passenger side. This is on a 2001 and I know they changed up the lines that year.
I couldn't even figure it out with the repair manual. Sorry for being dumb
Also this is NOT the line that goes into the throttle body that line is connected.
vacuum.jpg?t=1264706278
Old Jan 28, 2010 | 02:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Is that for the cruise control up under the air cleaner? My old truck did not have cruise and I have not looked at that yet on my new one.
Old Jan 28, 2010 | 07:08 PM
quackaddict
Where would it hook up to the air cleaner?
Old Jan 28, 2010 | 07:31 PM
dhvaughan's Avatar
dhvaughan
here's some pics from my 01 that i took awhile back for someone. the only line that i see that wraps around the front is the cruise control - which runs over to the front left corner under the battery.
the only hose that goes to the air filter on my 01 is the vent from the passenger side valve cover, and its a bigger line.
Old Jan 28, 2010 | 07:38 PM
95RAM360's Avatar
95RAM360
there should be a place on the TB for a vacuum line, on the front left of it.
Old Jan 28, 2010 | 07:55 PM
Sheriff420's Avatar
Sheriff420
Originally Posted by dhvaughan
where does that vac line in the very top of the picture go?
my sisters 99 has that and my 2000 has it capped off. hers has the overhead console and it is a 360, but other than that they are the same. well almost, hers has bands that hold the u joint to the rear axle and mine has the plate deal like the front drive shaft to transfer case hookup.
Old Jan 28, 2010 | 08:13 PM
dhvaughan's Avatar
dhvaughan
^i'll check tomorrow. i think it goes to the t-case.
Old Mar 26, 2011 | 01:40 PM
Army-Dodge21's Avatar
Army-Dodge21
it does go to the T-Case...But I'm actually trying to figure out the same vacum line on the intake and also the one on the front of the throttlebody..
Old Mar 26, 2011 | 01:47 PM
bekins01ram's Avatar
bekins01ram
From what I can tell, That looks like my cruise control hose on my '01. Look underneath the battery at the cruise control module. Follow that vacuum hose out, and see if it goes anywhere. Mine runs over to that T, that you have pics of coming outta the manifold.
Old Mar 26, 2011 | 03:25 PM
Army-Dodge21
Same here now just for the throttle body....Hopefully that solves my stalling problem to...I can be going down the road or driving down the drive way and it just quite? i have no idea what it is lol
