Deathflash?????
Old Jan 28, 2010 | 10:52 PM
pwalters's Avatar
pwalters
Default Deathflash?????
Just wondering what the Deathflash is and if there is a way to check if i have it or not. Thanks for the info
Old Jan 28, 2010 | 11:02 PM
PurplDodge's Avatar
PurplDodge
Search. There are many threads on it.
Old Jan 29, 2010 | 12:28 AM
jasonw's Avatar
jasonw
Site Moderator
In short, its Chrysler's "solution" to the broken plenum gasket issue.
Purpl's right. Do a search for either, and you'll find your answer. Welcome to the forums!
Old Jan 29, 2010 | 09:34 PM
pwalters's Avatar
pwalters
Does the plenum gasket make a differance once it is fixed i did look at some info for it. Also was this deathflash something that they only did to certain years i have a 1999.
Old Jan 29, 2010 | 10:14 PM
1fast2liter's Avatar
1fast2liter
yes a big difference till you blow it again unless you go with the hughes kit or a diy plate.. its a 99 more then likly it has the flash.. look for a sticker onthe ecu or rad support saying it was serviced in 2000 or 2001...
Old Jan 29, 2010 | 10:32 PM
pwalters's Avatar
pwalters
Ok i looked and orderd the hughes kit what programer do you recommened to get rid of the flash.
Old Jan 31, 2010 | 08:01 PM
PurplDodge's Avatar
PurplDodge
Superchips.
