vibration after lift kit in 4x4
Old Jan 30, 2010 | 12:04 AM
Cheat's Avatar
Cheat
Default vibration after lift kit in 4x4
I have this vibration in my drive train only in 4x4 above 35mph. Ive had someone tell me its my drive shaft. Its a rough country 5" lift. Any ideas? It also goes away after you let off the gas, but comes right back when you press the gas.
Old Jan 30, 2010 | 12:56 AM
95MaroonMonster's Avatar
95MaroonMonster
could be a u-joint on one of the shafts, or the bearing on the slip yolk on the rear output of the t-case (that much lift is VERY tough on slip yolk bearings, believe me, my cherokee has the same case)
Old Jan 30, 2010 | 05:33 AM
Dakine69302's Avatar
Dakine69302
agreed, climb underneith and check ur u-joints
Old Jan 30, 2010 | 11:25 AM
dodgeram07's Avatar
dodgeram07
you think the lift put to much algill on the drive shafts
Old Jan 30, 2010 | 11:33 AM
meanwhitemopar's Avatar
meanwhitemopar
its not to much angle... i have 10 inch... and i run the stock driveshaft...
check your ujoints... and grab your front driveshaft.. give it a shack... make sre those slip bearings are good
Old Jan 30, 2010 | 11:47 AM
dhvaughan's Avatar
dhvaughan
braggart.
vibration is likely to be coming from front drive shaft u-joints.
Old Jan 30, 2010 | 12:47 PM
95MaroonMonster
Originally Posted by dhvaughan
braggart.
wow...
...we can't have a single thread without someone making an off topic perverted comment...that's just us second gen guys for ya lol
