5.2 Extra Vacuum Port???
Old Jan 30, 2010 | 12:14 AM
mnewbolds's Avatar
mnewbolds
Exclamation 5.2 Extra Vacuum Port???
I just reassembled my motor after a Hughes plenum swap and I seem to have an extra vacuum port on the drivers side of the intake. I know one is for the Brake Booster, and one goes to the vacuum junction above the valve cover on the drivers side. But for some reason there is another port and for the life of me, I cannot find a loose vacuum line anywhere. Not even a Cap! I notice the vacuum diagram for a 5.2 in the Haynes Manual only shows 2 ports on that side but the 5.9 has 3 ports. Mine is a Factory 5.2 truck, I know that is a fact, my father bought it new. What's the deal? Any one know, or help!?!?!
Old Jan 30, 2010 | 12:23 AM
95MaroonMonster's Avatar
95MaroonMonster
it should be capped, my 95 318 only has 2 used vac lines on the left side and 3 on the right...pain in my azz if you ask me
Old Jan 30, 2010 | 12:27 AM
mnewbolds's Avatar
mnewbolds
Yeah, that threw me off, I have 3 on each side. Is it possible the factory "accidentally" put a 5.9 intake on my 5.2?
Old Jan 30, 2010 | 12:33 AM
95MaroonMonster
mine has all 3 ports, one just has a black plastic/rubber cap, i'll take a picture tomorrow
what does the diagram on your core support show??
Old Jan 30, 2010 | 12:35 AM
mnewbolds's Avatar
mnewbolds
Right on, I think I read your post in the cb thread. I was worried you had both the antennas hooked up. Wiped the sweat when you said ones for show! Thanks for the come back though.
Old Jan 30, 2010 | 12:39 AM
95MaroonMonster
i used to have both hooked up but my SWRs were way outta whack when i put my uncles meter on it, there still not great, about 2:1, but i may have a piece of coax going bad (i routed it under the truck, and through the boot for the t/case
Old Jan 30, 2010 | 07:07 AM
95RAM360's Avatar
95RAM360
they are the same thing. i got a 5.2L manifold in my 5.9L
Old Jan 30, 2010 | 08:29 AM
mnewbolds's Avatar
mnewbolds
I understand they are the same, but the problem lies with the vacuum ports. 5.2 has 2 ports on the drivers side, and the 5.9 has 3 ports. The question is do I plug it or is it used?
Old Jan 30, 2010 | 08:34 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Just plug it. You'll know soon enough if something didn't get connected to it. One of them is just a test port.
Old Jan 30, 2010 | 09:36 AM
97Dodge's Avatar
97Dodge
Yeah just plug it.
