wheels leaning in/out
Old Jan 30, 2010 | 01:18 AM
98ram318's Avatar
98ram318
Default wheels leaning in/out
So when my truck is just sitting there, the wheels kinda look like this /----\ but if i drive it around the turn into my garage or around anywhere, sometimes the wheels look like this \----/. im on stock rims and tires, my ball joints are fine, idk what it is..
any one else have anything familiar happening?
Old Jan 30, 2010 | 01:44 AM
dakotas ram's Avatar
dakotas ram
wheel bearings?
Old Jan 30, 2010 | 07:01 AM
95RAM360's Avatar
95RAM360
mine did that, only one side though...caused a small hop when turned all the way, and it was a wheel bearing.
Old Jan 30, 2010 | 11:20 AM
dhvaughan's Avatar
dhvaughan
test wheel bearings (and ball joints) by grabbing the top of the tire and pulling/pushing with all your might. any in/out movement or sound indicates a problem. it should be tight.
Old Jan 30, 2010 | 11:29 AM
Augiedoggy's Avatar
Augiedoggy
I guess it should be mentioned the tire has to be jacked up to make it easier the see if the bearing is shot...
Old Jan 30, 2010 | 11:33 AM
dodgeram07's Avatar
dodgeram07
that is a pic of a bad wheel bearing
Old Jan 30, 2010 | 11:40 AM
dhvaughan's Avatar
dhvaughan
not really. if you pull really hard, and its worn out, it'll move.
Old Jan 30, 2010 | 12:56 PM
98ram318's Avatar
98ram318
thanks for the responses guys, yeah that pic of the bad wheel bearing pretty much looks just like my truck does... thing is though is that i put a bar under the tire while it was jacked up and there wasnt any movement, and then took the wheel off and grabbed the brake rotor and there wasnt movement... im stumped by it...
Old Jan 30, 2010 | 03:32 PM
dakotas ram
look under there while on the ground and someone turning
Old Jan 30, 2010 | 04:06 PM
95RAM360's Avatar
95RAM360
+1 i could hear my clunking a little bit too
