97 Ram ClubCab Shift Problem
Old Jan 30, 2010 | 03:41 PM
hashhu's Avatar
hashhu
Default 97 Ram ClubCab Shift Problem
I have to take my foot off the gas when the trans wants to shift when going between 44 - 50 kmph. As soon as I remove my foot the truck will shift. This is under normal accel... However, if i use a heavy foot, it will shift through all gears as normal and smooth. Any ideas?
Old Jan 30, 2010 | 05:40 PM
Augiedoggy's Avatar
Augiedoggy
yep....normal gets that way when the govener pressure sensor or soleniod are on their way out...easy fix...
I noticed your handle....into FTA are we?....I belong to that site...
Old Jan 30, 2010 | 05:44 PM
mudxslinger's Avatar
mudxslinger
i have the same problem
mines a 96 though
Old Jan 30, 2010 | 05:53 PM
hashhu's Avatar
hashhu
lol, yea,I grabbed that hashhu title way back when they were handing out free gmail invites when gmail was first starting out. I miss the place, was a good forum.
Any way to find out if is one or the other, or just start replacing? Tough job? Expensive ?
Old Jan 30, 2010 | 05:59 PM
Augiedoggy's Avatar
Augiedoggy
if you take it to an auto parts store and throw it on a code reader it may give you a 1741 code like mine did to help pinpoint but you should replace both at the same time...about 100 bucks if you order them online plus filter and about 5 quarts of fluid... $200 for everything at dealership takes and hour to 1 1/2 hr to do with manual as guide found here if you search "merry christmas"
Old Jan 30, 2010 | 06:07 PM
hashhu's Avatar
hashhu
Will give it a shot, Thanks!
Old Jan 30, 2010 | 09:07 PM
hashhu's Avatar
hashhu
Thanks for the heads up on the "merry christmas" manual...WOW!!!
Last question, would a code be stored even if the CE light is not on?
Old Jan 31, 2010 | 12:53 AM
Augiedoggy's Avatar
Augiedoggy
Yes I had no light
Old Jan 31, 2010 | 08:01 AM
hashhu's Avatar
hashhu
ok, Thanks again.
Will let you know how it turns out.
