2nd to 3rd Gear Shifting Issue
Old Feb 1, 2010 | 12:59 PM
xjarhead69's Avatar
xjarhead69
Originally Posted by Augiedoggy
yes thats because you have the earlier hydraulic transmission sorry...missed the "95" in your info....the later 46re that most 96 and on have uses two soleniods one for od and lockup and the gov pressure one for the other shifts.... baybe your tv cable is out of adjustment? sorry I dont know how to adjust it but others here do and may chime in...
Try this link for tv cable adjustment.
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
Mine is 96 and the cable locking devise is designed differently then what is shown in the link above. It does not come off on mine it is just pushed in from passenger side toward the drive side and held there as you adjust the cable. Then when you have the cable where you want it just release it.
This is also different then what is shown in the manual on this forum that is free for download.
Dave
Old Feb 1, 2010 | 05:59 PM
Kawman10's Avatar
Kawman10
HHMM Just My Ruck.. I'm hoping since the other owner didn't drive it much,maybe a fluid, filter change might help? I've read trans x and such additives don't work? Anyone had any luck in a trans like mine ? Thinking I may try it.
Old Feb 4, 2010 | 05:43 PM
Kawman10's Avatar
Kawman10
Ok I've read the article above about TP Cable. I didn't see a warning about any Spring Tension On This Cable? Is It Gonna Move when I Unclip It ? I've Driven Enough Now To Know It Will Shift Going Up A Hill With More Throttle Being Applied. I Want To Adjust It For Later, Firmer Shifts, But Don't Want It To Come Unattached If Thats Possible? Or Pull Out If It Has Tension On It.
