WOW superchips
Old Feb 5, 2010 | 10:51 PM
  #51
CSXfan's Avatar
CSXfan
Originally Posted by ophidia
Also, how much difference does the economy tune make? Let's get some user testimonials here. It's hard to trust the claims made by 99.999% of the "quick performance" manufacturers out there.
91 tune-noticeable top end gain, no low end improvement, no gas mileage improvment
89 tune-noticeable top end gain, no low end improvement, no gas mileage improvment
87 tune-didn't really notice anything
tow mode-maybe some low end improvment? No top end, horrible gas mileage (I went from 13mpg to 10 without even towing anything)
fuel economy-no performance increases, +1 mpg
This is just what I felt/estimated in my '99 5.9l 4x4. I usually use the 91 tune with 89 octane gas and I have no issues. I have run the 91 tune with 87 octane and had no issues but I wouldn't recommend it.
Old Feb 6, 2010 | 05:55 AM
  #52
BlueBeast2's Avatar
BlueBeast2
Originally Posted by fasthemi87
i going to get a chip for my 04 dodge ram hemi looken for answers about up grades such as a super charger which im saving up for while im in iraq it will take me all year
to do soo what do i need to install before and after the supercharger i have some ideas any info will be helpful looken to make it a performance truck thx
you need an SCT for all that. Forget the chip
Old Feb 6, 2010 | 09:10 AM
  #53
Sheriff420's Avatar
Sheriff420
Originally Posted by gary30mazak
Does it really matter if you have it programmed to 91 octante tune and only run regular 87 octane fuel? Mine set to the performance tune but i'm sick of paying for that high price gas,.
the manual says that the engine can start pinging on the 91 or 89 tune with 87 octane, but with a good plenum gasket it shouldn't ping.
i got different results on the short trip i took, as soon as i put it in gear it started walking faster then it normally does. and it felt more punchy through the gears until it hit overdrive. i'll have a little more diagnostic time (gas draining time) with it here shortly because i'm about to go to a town that is 30 miles away to weld a glass pack on.
Old Feb 6, 2010 | 11:32 AM
  #54
Twisted Metal's Avatar
Twisted Metal
Originally Posted by Sheriff420
i installed mine a few minutes ago and took it for a 5-10 mile trip in the rain with it set to the 91 tune and 87 in the tank (no pinging either, thank you hughes). i also adjusted the tires to 32.75, but i can't remember if that does anything on our trucks.
it does feel stronger through the gears and is about the same if not barely better in overdrive.
now the last time i got on it was when i was running the stock air box for a while, and now that the 14x3 is back on, it might be affecting the feel of more power at WOT.
so, superchips users, did it take a few miles before you started to really feel the effects of the tuner or was it an immediate difference?
I have had my 3815 for about 6 months now. It took a tank of gas before I felt a difference when using 91 Performance tune. You can run 87 octane gas with the 91 tune. Mine pinged like and SOB under hard acceleration. I am not 100% sure that the ping may or may not be plenum related. One nice thing about the 3815 is that it is internet updateable. Which basically gave me SC's new Mileage XS tune for free.( its basically the 87 tune with a little more performance). Just for S&G's I set it back to stock tune, and WOW. Needless to say it didn't stay on stock for very long. Mind you SC, or Hypertech are not "nitrous in a plug in". SCT tuners are custom mapped to your engine, they are still the best "pure tune" to your truck. But SC is stupid simple to use, and does do a nice job with the canned tunes it comes with. I recomend SC's to anyone who is looking for a very simple mod for thier truck, it does get rid of the death flash. I plan on using and keeping mine till I decide down the road what direction I wanna go with this engine.
Sheriff, the tire size adjusts the speedo to tire size. Its not 100% accurate, mine is 2 mph off when checked against my GPS.
Old Feb 6, 2010 | 01:02 PM
  #55
lastrights's Avatar
lastrights
i noticed the power off the bat, its just so much easyier to get up to speed
Old Feb 6, 2010 | 01:27 PM
  #56
hydrashocker's Avatar
hydrashocker
The 1:7 first if your really going to be modifying your rig. If your not into doing a complete turn around (complete modified overhaul) then go for the tuner. Most people are not going to get into serious modifications, therefore a tuner is the way to go. From the years I've been in modification there really is 2 different options out there.
As for "chips", The PCM on these rigs learn the settings then turn it down anyway. The only way around this is for you to reset the PCM when it learns the tune. This could be in 48 starts and up in the 300 mile range and/or longer. I do NOT support the use of "Chips" and instead support the use of tuners because you actually change the parameters of the PCM.
Old Feb 6, 2010 | 05:24 PM
  #57
Chadlow21's Avatar
Chadlow21
Originally Posted by PurplDodge
How much?
I sent you a PM
Old Feb 14, 2010 | 03:49 PM
  #58
ophidia's Avatar
ophidia
Finally got mine and installed the performance tune. The only difference I can tell is the TC locks up at 45-50 instead of 40 like it's been doing. I noticed no performance gains, which sucks. Boo.
Any thoughts? I do have 89 in it but noticed no pinging.
Old Feb 14, 2010 | 04:05 PM
  #59
ophidia's Avatar
ophidia
Oh, and it used more gas :P
Old Feb 14, 2010 | 07:45 PM
  #60
CSXfan's Avatar
CSXfan
That's exactly what I thought when I installed my 3815. No performance gains but the TC locked up later, which is nice. Now the engine doesn't lug at 1200rpm at 40 mph. I think that, and the fact that you can read engine codes makes the programmer worth it.
