Transmissions Guys? Fresh Rebuilt Trans (46re) won't shift into OD!
Old Feb 4, 2010 | 08:11 PM
dhvaughan's Avatar
dhvaughan
hopefully it will all work out ok.
TC lock/unlock only changes the rpm by about 200-300, while OD is much bigger change on the tach.
look on the bright side, the trans gets a good second look/test while in the truck.
i wonder how much/what kind of testing it received after the rebuild before you put it in the truck. does it look like they have any kind of test bench where they would test a transmission before its installed ? probably not.
Old Feb 4, 2010 | 08:34 PM
overs ram's Avatar
overs ram
"i wonder how much/what kind of testing it received after the rebuild before you put it in the truck. does it look like they have any kind of test bench where they would test a transmission before its installed ?"
No dyno/test bench, I'll ask what all and how they test, I checked out most of the shop
*the place I almost used has a dyno set up with engine, but there bad reputation made me keep looking
...when I picked up trans after rebuilt, I saw most of there work area and its clean and organized but not the best I've seen, the guy who did my rebuild sounds as if he has a lot of experience "dodge guy", and took the time to talk to me, answer questions and volunteer information and gave me the old pump
after having to put in a new pump and now wiring harness, I imagine there profit margin is now smaller
Old Feb 4, 2010 | 08:37 PM
overs ram's Avatar
overs ram
Originally Posted by 95RAM360
id say it has something to do wth the wires in the valve body....
I forgot, you win the prize!
Old Mar 22, 2010 | 11:25 PM
Wright14530's Avatar
Wright14530
I am having the same problem. I just put rebuilt 46RE tranny into my 2000 ram 1500. Instalation was good but now it will not shift into 4th/OD.
Old Mar 22, 2010 | 11:58 PM
J415's Avatar
J415
Start your own thread so that you get the answers you need. No thread jacking.
Old Mar 23, 2010 | 06:21 AM
Wright14530
Default No
Now why would I want to do that when I can talk to some one with the same problem. Makes way more since to do it this way. Oh yeah and your gay.
Old May 30, 2010 | 11:16 PM
jasonw's Avatar
jasonw
Site Moderator
Thumbs down
Actually, it makes way less sense when the original poster hasn't been to Dodge Forum in over two months. I'd follow J415's advice.
First, if you're going to insult someone, you need to learn to use proper grammar. It should be "you're". Second, I think you need to take a look at the Dodge Forum rules. Specifically, rule #2.
2. While debating and discussion is fine, respect your fellow enthusiasts. Being of a diverse background, members are likely to express different opinions, and while opinions may differ from yours, they are just that, opinions; and everyone is entitled to express theirs freely. We will not tolerate rudeness, insulting posts, or personal attacks. Do not flame, bother, bug, disrespect, hound or taunt ANYONE on the forums or through private messaging or chat room. If we feel a thread is getting out of hand we will close or delete it. You can/will lose your posting privileges if you continue this type of behavior.
You can find a full copy of the rules here.
Further more, if you want future help with this problem, make your own thread, because this one is closed. Have a nice day.
