kick down cable adjustment
Old Feb 1, 2010 | 01:43 PM
bluebomber2500's Avatar
bluebomber2500
Default kick down cable adjustment
my 97 ram with the 5.9 v-8 and i believe the 47re trans needs the kickdown cable adjusted. under normal acceleration it goes into 3rd around 40 mph, then back to 2nd around 45mph, then back to 3rd around 50, then OD and everything is fine after that. I was told by a friend with a 98 grand cherokee with the 5.9 how to adjust it. I thought cause the motors and trans's are the same, the adjustment would be the same, but i guess it isn't. Any info on this i would appriate it.
Thanks, Brian
Old Feb 1, 2010 | 01:52 PM
cmckenna's Avatar
cmckenna
www.fbthrottlebodies.com Ask Bruce for his instructions. I went through this with mine at the time of installing my TB but, I don't have the instructions with me out here on the east coast. Just ask him for them and he'll send them to you.
CM
Old Feb 1, 2010 | 02:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
This does not help if you lost the factory setting, but will help with adjusting after you get it back to stock. http://www.bionicdodge.com/Download/...Adjustment.pdf
If you download this it will get you back to factory spec. https://dodgeforum.com/forum/2nd-gen...tmas-guys.html
Old Feb 1, 2010 | 03:01 PM
zman17's Avatar
zman17
Go to this thread, there is directions out of the FSM. https://dodgeforum.com/forum/2nd-gen...-in-trans.html
Old Feb 1, 2010 | 03:51 PM
bluebomber2500
thnaks for the info, ill give it a try later this week when i warms up into the 30s. i think ill start at an 1/8th of an inch forward and go from there.
Old Feb 1, 2010 | 05:04 PM
1fast2liter's Avatar
1fast2liter
you have a 46re.... same as a 1500... if you had a v10 or ctd then you would have the 47re
Old Sep 26, 2016 | 04:11 PM
CountryAngel's Avatar
CountryAngel
Default Kick down cable
I gotta dodge 97 ram 1500 kick down cable needs replaced. Can i do it myself or is there computer specs involved?
Old Sep 26, 2016 | 07:35 PM
dbbd1's Avatar
dbbd1
Yes, you can do it. Easy-peasy.
