Speedometer
Old Feb 3, 2010 | 06:22 AM
JediSky671's Avatar
JediSky671
Default Speedometer
anyone's speedometer and odometer not working?what's the fix for these?My Ram is a 98' 1500 5.2 4x2.
Old Feb 3, 2010 | 07:33 AM
zman17's Avatar
zman17
Retired Moderator - RIP
On a 98 the cause can either be the sensor on the tail shaft of tranny or the sensor on top of the rear end housing. Do you have the ABS and Brake light on too?
Old Feb 3, 2010 | 07:53 AM
JediSky671's Avatar
JediSky671
Default yeah
Yeah the ABS and brake are on too.Any fix and is it expensive?
Old Feb 3, 2010 | 09:16 AM
zman17's Avatar
zman17
It's most likely the sensor on top of the rear end. Around $50.
Old Feb 3, 2010 | 10:15 AM
zje400ex's Avatar
zje400ex
Yep. That should fix the lights and the speedo. Some places have them for around $30 and other places are a bit more. Easy to install and should fix it
Old Feb 3, 2010 | 05:41 PM
JediSky671's Avatar
JediSky671
Default Hey
Hey guys what's the actual name of the part?I called and they have some ABS thing for the rear differential.
Old Feb 4, 2010 | 07:21 AM
zman17's Avatar
zman17
Rear wheel speed sensor.
Old Feb 4, 2010 | 10:05 AM
95RAM360's Avatar
95RAM360
it will take under 10 minutes to change out, its very easy.
