How do I replace the speed sensor?
Old Feb 3, 2010 | 09:27 PM
yakkier's Avatar
yakkier
if the the abs lights and brake lights went off then just reset your comp, disconnect your neg cable and turn your key on for about 10 seconds to drain the power to the comp, forces it to reset. hook the neg cable back up an crank the truck and the CEL should go off.
Old Feb 3, 2010 | 10:42 PM
yakkier's Avatar
yakkier
For future refference if you do decide to change the one on the tranny
this one is of the nutural/reverse light sensor, it's right next to the transmission oil pan on the drivers side
and if you look above it you will see your speed sensor.
heres a picture of the area so you can kinda guage where it's at
Old Feb 3, 2010 | 11:01 PM
dhvaughan's Avatar
dhvaughan
hey yak, i can't see your pic's very good.
but are you taking pics of this? its on the output shaft of the trans or t-case.
http://www.rockauto.com/catalog/x,ca...parttype,10280
Old Feb 3, 2010 | 11:05 PM
yakkier's Avatar
yakkier
Yea thats the one, i cant get a real good pic of it cause my f-in skidplate is in the way, just kinda tryin to give him a general area to look at
Old Feb 4, 2010 | 08:18 AM
dakotas ram's Avatar
dakotas ram
ummm, are the 2wd ones different? i just changed mine a couple months ago and this is what it looks like
http://www.autozone.com/autozone/cat...&parentId=59-0
