96 v10
Old Feb 4, 2010 | 08:40 AM
watglen's Avatar
watglen
Default 96 v10
Hi guys,
New here, but i can use some advice.
My 96 dodge v10 is acting up. At high rpm it sounds like a diesel. It is intermittent and i cant quite describe it properly, but if i back off the throttle just a bit when at higher rpm or higher load, it sounds like a diesel engine for a second. Not sure if this is called pre-ignition or something else.
I'm sure i seen a tsb on this, any ideas?
Ken
Old Feb 4, 2010 | 06:58 PM
VEETEN's Avatar
VEETEN
are you "pinging"?
That is it sounds like someone is hitting the engine with a wrench?
If yes...... first check both CATS
Old Feb 4, 2010 | 07:03 PM
PurplDodge's Avatar
PurplDodge
Does it go "brum-brum-bum-bum-bom" when you back off the throttle?
Old Feb 4, 2010 | 07:17 PM
VEETEN's Avatar
VEETEN
Son What the He#@ is up with that sig?????
