Trans problem on 94 5.9l
Old Feb 4, 2010 | 06:06 PM
Resz's Avatar
Resz
Unhappy Trans problem on 94 5.9l
I have a 1994 4x4 with the 5.9l in it. Its a project truck and the transmission was slipping and had no reverse. But it didnt leak. I changed the filter, put on a new gasket, cleaned the magnet, and added 4.1 qts of atf +4. The truck seemed like it shifted a little better and i drove it for a bit and parked it and let it run for a bit and just manually shifted through the gears. There weren't any leaks or anything like that. I parked it in my friends garage and went back to college. I dont know how long it took but apparently when my friend went out to his garage 3 days later there was trans fluid all over. The truck hadnt been driven. Im going back this weekend and will be trying to fix it, I just want to know what could have caused it to leak out later when it wasn't driven.
Old Feb 4, 2010 | 07:06 PM
Gerehead8's Avatar
Gerehead8
Crack in the oil pan, bad pan gasket (likely because you dropped the pan, leaking dipstick o-ring, bad seal between tranny - t-case, crack in tranny, ect.
