Truck stored 2 years, now won't start
Old Feb 6, 2010 | 02:32 PM
  #21
yakkier's Avatar
yakkier
if you can, most people cant take them off before dropping the tank, so i personally would jack up the tank enough to loosen the straps, take the straps down on one side and slowly lower the tank to where you can get your hand in there to disconnect the hoses. then once u get them disconnected just fully drop the tank to the ground and clean it out
Old Feb 6, 2010 | 02:51 PM
  #22
dakotas ram's Avatar
dakotas ram
dont forget that your filler hose is also connected
Old Feb 6, 2010 | 04:35 PM
  #23
cwally12's Avatar
cwally12
is there a tool to get the pump outta the tank?
Old Feb 6, 2010 | 04:43 PM
  #24
dakotas ram
i think it just unbolts
Old Feb 6, 2010 | 04:48 PM
  #25
cwally12's Avatar
cwally12
its got like a screw on cap
Old Feb 6, 2010 | 04:55 PM
  #26
yakkier's Avatar
yakkier
take a flathead screwdriver an a hammer and tap it to the left, just dont break it.
remember right = tight left = loose.
Old Feb 6, 2010 | 04:59 PM
  #27
dakotas ram
ok, i knew the older tanks had the ring, hadnt ever dropped my rams tho.....+1^ about the screwdriver......they do make a tool, but theres no point
Old Feb 6, 2010 | 05:02 PM
  #28
Laramie1997's Avatar
Laramie1997
A large screw driver might work, but you would be much better off with a short piece of a 2X4. Less of a chance of you driving it through the ring or the tank than with that screw driver.
Old Feb 6, 2010 | 05:03 PM
  #29
yakkier's Avatar
yakkier
heres the tool they sell for it, but it's not worth the money.
http://cgi.ebay.com/ebaymotors/Mille...item20aeba0ceb
Old Feb 7, 2010 | 07:16 PM
  #30
cwally12's Avatar
cwally12
found a strap wrench at advanced 8 bucks got the job done puttin new pump in tomorrow
