Rear Diff 4:56 gears noise
Old Feb 6, 2010 | 05:46 AM
Gnarkill666's Avatar
Gnarkill666
Default Rear Diff 4:56 gears noise
Noise is driving me nuts Hub bearings wasnt it and the transfer case wasnt it, tired of throwing money at it. Put it on jack stands today spun it to 50 ish let off the gas and sure enough its louder then on the road and coming right out of the rear diff or atleast you can feel it there. Its a bad chattering that you can feel pretty good with your hand on the diff cover. I popped the cover off and no sign of of wear, scraping or a single piece of metal in the gear oil. the magnet in the bottom was clean also. Any thoughts???
Old Feb 6, 2010 | 07:49 AM
dhvaughan's Avatar
dhvaughan
noise is generally from either the gear itself, or the pinion bearing. what's the story here, is it new, old, what. have you got a warranty on it. is it setup right.
my daughters 4runner rear end got really loud. it'd make a roar on acceleration and a growl on decel. with it up on jacks and drive shaft disconnected, and spining the yoke by hand, i could feel the loose pinion roar.
Old Feb 6, 2010 | 02:55 PM
Gnarkill666
they were put in 4 years ago by 4wheelparts so what ever warranty there was is gone, its only on decel that you can hear it, as far as i know its setup right. when i took the cover off couldnt feel anything by hand spinning it, no slop of or anything i could see that way, thinking the bearing is a good culprit.
Old Feb 6, 2010 | 05:38 PM
yakkier's Avatar
yakkier
sounds like some of the dogteeth might be either shifting or slipping. try putting some fresh 90weight oil in and go from there
Old Feb 6, 2010 | 05:47 PM
sit22 II's Avatar
sit22 II
im the same shoes rite now. the only time i hear the noise is when i let off the gas pedal
Old Feb 6, 2010 | 05:48 PM
yakkier's Avatar
yakkier
Sure it's not your exhaust rattling ?
Old Feb 7, 2010 | 12:09 AM
Gnarkill666
If your talking to me definately, in the first post i described it you can feel the chattering on the diff cover itself.
Old Feb 7, 2010 | 12:19 AM
sit22 II's Avatar
sit22 II
i was asking around and i was told to check the rear bearings, pinion bearing (not really looking for that one) and the u joints.....
Old Feb 7, 2010 | 12:46 AM
yakkier's Avatar
yakkier
No that one was for the other guy. man to be honest with you if nothing is loose, id consider putting the rearend on jackstands and take the diff cover off again, and try and spin the tires a lil and see if anything is slipping. If you havent already tried that with the diff cover off while you're doing it.
Old Feb 7, 2010 | 04:03 AM
Hahns5.2's Avatar
Hahns5.2
Nothing is slipping, there would have been PLENTY of evidence of that (if it's even possible) when he had the diff cover off, sure sounds like pinion bearings to me..
