bad cat?
Old Feb 7, 2010 | 07:06 PM
rumble_truck's Avatar
rumble_truck
Default bad cat?
Well, I go to start my truck this morning and it's quiet as hell, (exhaust was torn out before the stock muffler). Now I cant tell it's running. My first thought was a bad cat, took it for a spin and I dont really notice a power loss, it's always been slow. When I put it in park it and give it some gas I hear a faint rattling noise.
Think my cats bad?
Edit: Spoke too soon, went to go to school this morning and floored it went about 10mph. Had to crawl back home. guess they're bad =P
Old Feb 7, 2010 | 07:46 PM
Weldor's Avatar
Weldor
Yup bad cat, gut it or replace it.
Old Feb 7, 2010 | 08:14 PM
95RAM360's Avatar
95RAM360
replace the 02 sensor as well.
also search the "Plenum Gasket" this could be the cause of the bad cat.
Old Feb 7, 2010 | 08:37 PM
mctdi's Avatar
mctdi
Take a rubber mallet, and hit the bottom of the cat, up-ward. Listen for loose pieces.
Old Feb 7, 2010 | 10:10 PM
yakkier's Avatar
yakkier
How far back does the plenum issue run, like could my 94 be effected by it. and what problems would it cause other than clogging up the cat.
Old Feb 8, 2010 | 01:58 AM
rumble_truck
Best way to do this? i heard of knocking it out with a pry bar and hitting the catalyst out with a hammer. I saw someone just cut it open with angle grinder, take it out, then weld it back together. Thoughts?
Old Feb 8, 2010 | 02:35 AM
J415's Avatar
J415
I know for sure, it's 94 -01. All second genners. I've heard that the 3rd genners are having this problem also (still). One other problem you'll have is loss of power.
Old Feb 8, 2010 | 07:39 AM
95RAM360's Avatar
95RAM360
its can clog CAT, foul plugs, foul precat 02 sensor, make it run like crap, give you crappy mpgs, oil consumption, and yes yours will be affected, and have the problem. Its actually a really easy job to do. Just pay attention
Old Feb 8, 2010 | 11:45 AM
Weldor's Avatar
Weldor
The best way IMO is to cut the whole thing out and replace it with a y-pipe, that way you won't get a drone in the sound of your exhaust system.
Old Feb 8, 2010 | 12:11 PM
rumble_truck
Well, I cut a section in the cat, removed the honeycomb, and welded it backup. Man that thing sounds nasty. Time to weld on the glasspack.
