just did my plenum!
Old Feb 9, 2010 | 06:04 PM
  #21
01Green5.9L's Avatar
01Green5.9L
Originally Posted by pashtrd
Im getting ready to do my plenum next week. How big is the plenum plate approx L" x W"
I can get some aluminum from work. a pc 24" x 12.5" will cost me $2.00 Will that be big enough to make my own plate?
I just measured a plate on an old plenum I have and a piece 16" by 7" will do
Old Feb 9, 2010 | 07:36 PM
  #22
pashtrd's Avatar
pashtrd
Thank you very much!
Old Feb 10, 2010 | 06:50 AM
  #23
T.Davis46's Avatar
T.Davis46
Originally Posted by zman17
Nothing, just let it sit overnight before you tear into it. A cheap plastic tool from Autozone or wherever will disconnect it at the fuel rail along with a rag to soak up any spillage. wear eye protection anyway.
And disconnect the negative battery cable first , before you do anything else.
I am gonna be doing my plenum as soon as the weather warms a bit (cold and snowy in Indiana), but what is the plastic tool for and what is it?
Old Feb 10, 2010 | 07:28 AM
  #24
dhvaughan's Avatar
dhvaughan
fuel line disconnect is on the fuel rail, drivers side. size=3/8
expensive tool (not required)
http://www.sjdiscounttools.com/ap7836.html
cheap tool (fine)
http://www.sjdiscounttools.com/kdt3530.html
Old Feb 10, 2010 | 06:20 PM
  #25
T.Davis46's Avatar
T.Davis46
cheap tool (fine)
Thanks, very handy to know prior to changing the plenum, versus figuring it out during the project...any other hints that haven't been covered?
Old Feb 10, 2010 | 07:01 PM
  #26
PurplDodge's Avatar
PurplDodge
Damnit I cant wait to change my plenum here in about a month! I'm gonna use the APS kit. I'm thinking about not doing the kegger mod. But while I'm in there I'm gonna change the oil, distributor cap and rotor, timing chain, serpentine belt, all the hoses, spark plugs (NGK), and the front oxygen sensor (NTK).
Plus after I do that I will be getting the Harland Sharp 1.7 Roller Rockers from John Mercedes. PurplDodge will be running like a beast!!!!
Old Feb 10, 2010 | 07:29 PM
  #27
lastrights's Avatar
lastrights
i would reccomend getting the superchips before the harland sharps , i felt more power with the superchips
Old Feb 10, 2010 | 07:37 PM
  #28
PurplDodge's Avatar
PurplDodge
I'm gonna get a Superchips after I get the roller rockers.
Old Feb 10, 2010 | 07:48 PM
  #29
lastrights's Avatar
lastrights
awesome then you wont reconize your truck with both put on
Old Feb 10, 2010 | 08:21 PM
  #30
PurplDodge's Avatar
PurplDodge
I'm hoping I wont recongnize the truck after I put on the APS Plenum and all the stuff I listed above. Purpl is starting to show her age after 179,000 miles. I just want to have her running in tip-top shape before we start towing the camper in the spring.
