5.9l magnum powerwire?
Old Feb 9, 2010 | 08:15 AM
dakotas ram's Avatar
dakotas ram
yep, ive done it with no noticeable change, not sure on mpgs, dont keep track
Old Feb 9, 2010 | 09:28 AM
Maxx_Magnum's Avatar
Maxx_Magnum
for those who want to know what it is, without sifting through random threads brought up by the beloved SEARCH button
From AirRam.com:
The =POWER=WIRE=> Is a PLUG & PLAY mod that will give you 8-10HP with less than 1 minute to install. Advancing the timing for increased HP is an old trick that has been used for many years. With the newer computer controlled vehicles there are no distributors to adjust, so to gain additional timing advance we need to alter the signal from the air temperature sensor for the desired advance. Your PCM uses the Air Temperature sensors to help control timing and Air/Fuel ratio. Your O2 sensors keep your Air Fuel ratio nailed to 14.75:1 at all throttle positions except Wide Open Throttle (WOT) so the POWER WIRE can NOT cause you to run rich during normal driving because no matter what the AFR will be 14.75:1. For this reason The Power Wire has been reported to add 1-2MPG increase when driven lightly. But at WOT the Power Wire will add approximately 2.5% at WOT. When your at WOT you are more concerned with HP than MPG at that moment in time and while passing an additional 8-10RWHP is exactly what your looking for.
The POWER WIRE should not be confused with the "E-bay Mystery Mods" that just claim to give you HP without any explanation as to how that particular mod works... But we try to equip you with the information you need to make the best decision for your performance quest.
When installed the POWER WIRE alters the signal to your PCM making it think the intake air temperature is 20 degrees cooler than the actual temperature at "ALL TIMES". This timing advance is worth approximately 8-10RWHP
The POWER WIRE has been reported to richen the AFR by one full point at WOT, this is good if you have long tube headers and other mods that tend to lean out your AFR at WOT. Installing the POWER WIRE can help cure this lean condition.
On our G-Tech Pro Comp meter it showed a 10HP increase on a 2003 4.7L.
If you need to take it in for service, it takes just 10 seconds to return it back to stock with no evidence of this mod ever being installed!
This is a "PLUG & PLAY" MOD... We have done all the work for you! Gain 8-10HP and 1-2MPG in less than 1 minute, no wires to cut, no tools needed, will not harm your PCM!!! What more could you ask for?
Old Feb 9, 2010 | 10:10 AM
PurplDodge's Avatar
PurplDodge
I cannot believe you dumb 3rd genners pay $40 for some wire, connectors, and a resistor.
Old Feb 9, 2010 | 12:29 PM
Desert_Ram's Avatar
Desert_Ram
i would never but there is a write up on how to make your own for about 2 dollars!
Old Feb 9, 2010 | 04:37 PM
1fast2liter's Avatar
1fast2liter
they dont use a resistor in the power wire.. the wire is loger for relocating the ait to the tube away from the manifold.
Old Feb 9, 2010 | 06:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
LMAO, Yea it's got a HEMI
