Tire and rust removal questions
Old Feb 9, 2010 | 09:37 PM
RedfireRam's Avatar
RedfireRam
Default Tire and rust removal questions
Ok so i just got my truck and its got rust cause its from up north is there anything that i could use to help get rid of that or stop it. Its tires are also goin bald..how big of tires could i get on stock rims...i need a little bit more off road tread and will 6.5 speakers fit in my front door and front passenger door in place of the old 6.9 dont wanna get somethin that wouldent fit.....thats what she said..thanks for the help!!
Old Feb 9, 2010 | 09:54 PM
rczanstke's Avatar
rczanstke
To answer your tire question, I'm sure you can find your answer in here someplace:
https://dodgeforum.com/forum/2nd-gen...ires-size.html
As your are new here, I would recommend reading these:
https://dodgeforum.com/forum/2nd-gen...w-to-rams.html
https://dodgeforum.com/forum/2nd-gen-ram-faqs-143/
redheadhunter21's Avatar
redheadhunter21
First off fill your sig up with info on your truck, motor, 4x4, 4x2, and so on
Where is the rust you want to get rid of and how bad is it
if its 4x4 285/75/16 is the biggest tire before lifting you should be fine with stock rims
Old Feb 9, 2010 | 10:08 PM
rczanstke's Avatar
rczanstke
I apologize for the lack of a real answer to your questions.
I'm assuming the rust is on the wheel wells, or on the bottom of the door?
Old Feb 9, 2010 | 10:12 PM
StukaJU87's Avatar
StukaJU87
I bought my 97 1500 4x4 a couple months ago from a good friend who purchased it new. It only had 54,000 on it when I bought it. The outside of the truck still looks great, however ... the underside is downright scary looking. Everything is rusted underneath. Just horrrible. Already had both front brake lines replaced as well as the long one to the rear brakes. They were rusted so bad they were crumbling. I have seen much older cars with less rust.
My 94 Toyota 4x4 with 176,000 on it looked like new underneath compared to this truck.
Old Feb 10, 2010 | 09:48 AM
Aubrey's Avatar
Aubrey
Rust-o-leum makes a paint on product that changes it to black. There's also a spray on version. But you should really remove it and then coat things. POR is great.
Maybe 33's depending on what you have.
Probably but you'll need to make plates since 9" is bigger than 6.5".
Old Feb 10, 2010 | 10:03 AM
dakotas ram's Avatar
dakotas ram
yeah, 6.5s fit...i made adapter plates out of plexi, but most audio stores have em
