Engine no start
Old Feb 11, 2010 | 02:25 PM
kikidbird's Avatar
kikidbird
Default Engine no start
I did a cylinder head gasket change and now she won't start. My mileage indicator shows "NO BUS". Has any one had this experience before?
Old Feb 11, 2010 | 02:41 PM
cmckenna's Avatar
cmckenna
Default No BUSS
No BUSS is usually an indication that a ground wire that was removed during teardown is OPEN thus causing an open CKT at the PCM level thus the NO BUSS display at the cluster.
Check all of your grounds coming off both heads, along with any other wiring harnesses that you may have disconnected or anything else that was disconnected.
Just be sure to disconnect the NEG from the battery PRIOR to connecting any wiring harness connector, ground, relay etc etc.
Old Feb 11, 2010 | 02:44 PM
yakkier's Avatar
yakkier
^ i freakin love that guy lmao
Old Feb 11, 2010 | 06:47 PM
kikidbird's Avatar
kikidbird
Thanks
Old Feb 11, 2010 | 07:46 PM
dhvaughan's Avatar
dhvaughan
i had a NO BUS when i forgot to attach a wad of ground wires on the PS bracket.
Old Feb 13, 2010 | 11:07 AM
kikidbird's Avatar
kikidbird
Got it running, I missed a ground wire. I connected it and she fired up. Thanks!
