transfer case question
Old Feb 13, 2010 | 10:58 AM
White Ram's Avatar
White Ram
Default transfer case question
I've goy a '96 4x4 with a 318. I want to change the fluid in the transfer case (NP 231D), but I don't see the fill and drain plugs on the back like the Chilton's manual shows. What gives? And what fluid goes in it?
Old Feb 13, 2010 | 11:07 AM
dhvaughan's Avatar
dhvaughan
look for recessed 10mm hex head. drain at the bottom, fill near half way.
DONT use a 3/8" its likely to strip it.
if you don't have a 10mm hex wrench, use a 10mm bolt head. or is it 8? anyway its metric - don't strip it.
ATF+4 auto transmission fluid is recommended.
its 10mm = .3937
3/8= .375 (a perfect strip out opportunity) don't ask me how i know that....
Old Feb 13, 2010 | 11:52 AM
Sheriff420's Avatar
Sheriff420
get a 10mm allen socket for a 3/8" drive ratchet, much easier then using a regular allen wrench.
dhvaughan, i guess i got lucky the first 3 times i changed mine, i used a 3/8" until my sister told me that hers was a 10mm and i had to investigate on mine. its snug, but it is definitely 10mm.
Old Feb 13, 2010 | 01:17 PM
dhvaughan's Avatar
dhvaughan
mine was torqued in like it was holding the world together and i rounded it out with a 3/8 and a ratchet. i've got just enough nub left for a 10mm to grab it.
tip - put a little rtv or teflon on the threads and don't over torque it. its just a plug, not an axle nut.
Old Feb 13, 2010 | 01:44 PM
Gord.'s Avatar
Gord.
If it's like my 95, it won't be an allen plug. The drain and fill plugs on mine are a normal hex head but the head is quite large and shallow.
Gord.
