I have a hunch on why I get such bad MPG
Old Feb 14, 2010 | 10:55 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by 2001Ram
I havent checked my cat because I dont know how, and because my truck has 75K miles on it. I doubt it bad.
I dont think my temp sensor is bad.
Yes, truck was fully warmed up, and it was 42 degrees outside.
Even so, your cat can still be bad.
Take it to an exhaust shop and have the cat pressure tested (I think).
Laramie1997's Avatar
Laramie1997
Check where you buy gas
plugs/wires/cap/rotor
Cat
Your driving habits- Yes, even babying it can result in poor mileage in some cases
Your tires
For the actual coolant temp to read 183*, that's about right. At least that's what my OBDII scanner reads. Maybe run some injector cleaner through, and reevaluate your gas buying choices. Remember, even Texas gets a different blend of gas this time of year that not one vehicle performs well on. Outside temperature plays a role too. I've found that there are sweet spots in the weather in which my truck runs better and gets better mileage. Seems to me that the 40-45*F range works best for mine, but it could be different for you. At the moment, I average 11.5-14. All depends on what I'm doing.
Never forget, city driving in these trucks (well, any vehicle) wrecks havoc on MPGs.
Old Feb 14, 2010 | 11:01 PM
sit22 II's Avatar
sit22 II
Originally Posted by PurplDodge
Why do you say that?
hes got a 195 tstat and the sensor its rearing 183 ... to me the sensor its a lil lazy ...by saying that the sensor its taking to much time to get up there and engine running richer longer than it needs to
Old Feb 14, 2010 | 11:06 PM
PurplDodge's Avatar
PurplDodge
Just because there is a 195* thermostat in there doesnt mean that the truck is gonna run 195*.
Old Feb 14, 2010 | 11:07 PM
2001Ram's Avatar
2001Ram
Cat
Your tires
I try to mix it up, never go to any off brand places. I run injector cleaner every 3-4K. Brand new 265 BFG's all terain. I know plugs are new, wires are napa belden. I dont know how old the cap and rotor are. When I first got the truck, the screws were loose, and I could wobble it left and right. Might of fouled it out.
Old Feb 14, 2010 | 11:13 PM
PurplDodge's Avatar
PurplDodge
Those big BFGs will kill your MPG, too.
95MaroonMonster's Avatar
95MaroonMonster
case in point, i have a 195 and at speed, i run just about 210
Old Feb 14, 2010 | 11:18 PM
Laramie1997
Another thought, how are you calculating your mileage?
Old Feb 14, 2010 | 11:19 PM
sit22 II's Avatar
sit22 II
195 means that the tstat is starting to open at that temperature if hes not even reaching that temperature how did he even purge the system when he did the plenum
Old Feb 14, 2010 | 11:20 PM
sit22 II's Avatar
sit22 II
thats how its suppose to be
