Clunking in front end!
Old Feb 15, 2010 | 06:13 AM
cmares's Avatar
cmares
Default Clunking in front end!
In my '01 ram 4X4 I feel and hear a clunking under my feet while driving. I can feel it even on the smallest bumps in the road. When I apply the brake the feeling goes away. Does anyone have any idea what this could be? Thanks for any help.
Old Feb 15, 2010 | 06:16 AM
olyelr's Avatar
olyelr
Some of the more obvious things can be a worn track bar, ball joints, or even loose shocks. Check stuff like that.
Old Feb 15, 2010 | 09:46 AM
Sheriff420's Avatar
Sheriff420
get under there and start grabbing parts and give them a good jarring to see if you can find it.
Old Feb 15, 2010 | 10:36 AM
yakkier's Avatar
yakkier
Track bar, mine does the same thing.
Old Feb 15, 2010 | 10:45 AM
RamSport97's Avatar
RamSport97
Definitely check the shock mounts. Make sure the top mounts are nice and tight, and make sure the bottom mounts are torqued to 100 ft./lbs.
Old Feb 15, 2010 | 11:08 AM
quackaddict's Avatar
quackaddict
When I bought mine I could feel a vibration under my feet and hear a noise when hitting bumps. I thought crap wheel bearings, but it was not, checked ball joints, nope not that in fact they had been replaced with greasable ones. Turns out I had a broken sway bar link and a bad shock. Replaced the shock unhooked the sway bar, no more noise.
