2WD lift questions
Old Feb 26, 2010 | 07:14 PM
  #71
01greenram's Avatar
01greenram
what engine do you have with my 360 i take off a little slower think 33 is pushing it but if you go as big as i have do 35's
Old Feb 26, 2010 | 07:47 PM
  #72
pablo7's Avatar
pablo7
Its lifted with a Fabtech 6.5 in. kit comes with spindles upper arms for the front and blocks for the rear. It wanders like most other rams I suppose, the alingment is a bit off in front according to my alingment guy since we did the ball joints when I bought it and the tires where wearing on the inside he left the camber I guess you would call it, in other words the tops of the tires leaning out a bit. But I think I need a second opinion on that one??? Anyone??? As far as regearing some 4.56's would be sweet but its on the list along with about 10 other things.... but funds are lacking at the moment
File Type: jpg
Old Feb 26, 2010 | 07:55 PM
  #73
01greenram's Avatar
01greenram
same with me on the gears and other things
Old Feb 27, 2010 | 11:03 AM
  #74
RealReggaerider's Avatar
RealReggaerider
Nice.....i think im going your route Pablo...spindles and springs. But only 4 inches
Old Mar 1, 2010 | 01:51 PM
  #75
97r/tram's Avatar
97r/tram
Here's mine with a 2 inch leveling kit in the front and 3 inch blocks in the back. I haven't gotten around to putting in the 3 inch spindles to level it out yet.
Old Mar 3, 2010 | 09:14 AM
  #76
RealReggaerider
thanx 4 the pic tram....that gave me a comparison to pablos truck. So you went with the 4 inch lift correct ?
Old Mar 3, 2010 | 09:27 AM
  #77
EndIsNear's Avatar
EndIsNear
Ram's is actually only 2" in the front and 3" in the back.
This is a 4" lift...
This is 3" lift...
Old Mar 3, 2010 | 09:28 AM
  #78
RealReggaerider
I have another question.....if the kit says 4 inch lift and the spec`s says that the rear block is only 3inches ....and the front specs are 3 1/2 spindle, thats not a four inch kit. I might be off on my quote but basically the lift out back ,to me should be a four inch block...and 3 inch spindle with 3 inch springs(2 of the inches on the springs is to level it) am i wrong....augh this is crazy please explain
Old Mar 3, 2010 | 09:31 AM
  #79
RealReggaerider
ok mr endisnear....is that pic of the white truck yours? if so could you tell me what kit is on the truck. and what size tires are on the truck cause I like how the truck sits.
Old Mar 3, 2010 | 09:41 AM
  #80
EndIsNear's Avatar
EndIsNear
Alright, does the kit state there is a spacer or new springs? Basically, a 3" spindle is going to give you a 3" lift. Putting 3" springs WITH the 3" spindle, is going to give you 6" of lift.
That 4" lift picture isn't my truck, I found it online. I think it was in an older Truckin' magazine. It is a Rancho lift (which is no longer being made) consisting of 3" spindles and a stiffer spring to give you that extra 1". It also comes with a crossmember which I haven't seen in any other Dodge 2WD lift kit. Heres the link...
http://www.truckinweb.com/brandpages...cks/index.html
You could achieve the same 4" with spindles and spacers...
