No backpressure make run rich?
Old Feb 15, 2010 | 08:47 PM
ironman888's Avatar
ironman888
and i also replaced the timing chain and mapsensor
Old Feb 15, 2010 | 09:10 PM
redheadhunter21's Avatar
redheadhunter21
If you have an autozone or another parts store that will read the codes get them to read the code and give you the number, it could be that you got a bad 02 sensor and its making it run really rich
dhvaughan's Avatar
dhvaughan
try to read the codes with the key dance. on - off - on - off - on.
Old Feb 15, 2010 | 09:16 PM
ironman888's Avatar
ironman888
i can never get the key dance to work for my truck. Ya i will go by advance and let them read it. What are the chances of a new sensor being bad?
Old Feb 15, 2010 | 09:22 PM
redheadhunter21
well its not that common but it is possible
Old Feb 15, 2010 | 09:23 PM
ophidia's Avatar
ophidia
Key dance doesn't work on '99's.
Old Feb 16, 2010 | 03:00 AM
Sheriff420's Avatar
Sheriff420
True duals should really have an X pipe within reach of the upstream o2 sensor with the sensor in the center of the X.
Like this one
http://www.summitracing.com/parts/MPE-10791/?rtype=10
Old Feb 16, 2010 | 09:17 AM
HammerZ71's Avatar
HammerZ71
A bad code from the upstream sensor is probably your culprit.
As far as running rich from better airflow and less backpressure, I rather doubt it. I'm running a CAI, LT Headers, a Magnaflow Y and Cherry Bomb Extreme and along with my SC tuner advancing the timing, I had to install a 180* thermostat because I was running too lean...
