Debadging
wait for summer and park it out in the sun.
use a credit card, or PLASTIC putty knife, or razor blade scraper to remove the stickers. once you get a corner up, they come right off.
then wax.
then wax.
this is how i did mine
1. set my truck inside overnight at 50 degrees
2. used fishing line to saw in behined the badge, you will use quite a bit i got a roll for this, floss works too
3. i used ppg dx330 its a pre cleaner for paint but goo gone will work too to get the remaining glue off
4. lastly buff the area with a good polish
if you use a putty knife or credit card you run the risk of damaging the paint, its unlikely but i have took paint off by prying like that
the warmer you get it the easyer it is to remove, like i said i did mine around 50 degrees and it was pretty easy, but ive done about 100 before that in all kinds of temps, just take your time and youll be good
