Truck I might be looking
Old Feb 15, 2010 | 10:20 PM
logan horse's Avatar
logan horse
Default Truck I might be looking
Ok, guys I found a 1998 Dodge 1500 ext cab. short wheel. 318. 5.2L. But the tranny needs some work and the rear end is built but i might be able to get a deal on it. So what i want to know is what rear axles will work with it?
Old Feb 15, 2010 | 10:23 PM
Gerehead8's Avatar
Gerehead8
Anything if your good at fabbing. Direct bolt it - Chrlsyer 9.25 from a ram truck with the same gear ratio. Its the same axle thats in there.
Old Feb 15, 2010 | 10:32 PM
logan horse
Sorry let me be more precious What is the gear ratios and what rearend will mount in the spot with ease
Old Feb 15, 2010 | 10:36 PM
PurplDodge's Avatar
PurplDodge
Chrysler 9.25 rear end. Came in Dodge Rams. Any gear ratios will work. Preferably you would want to get the axle from a truck that has 3.92 or 4.10 gears.
Welcome to Dodge Forum
Old Feb 15, 2010 | 10:37 PM
Gerehead8's Avatar
Gerehead8
The ratio will most likely be 3.55. Is it a 4x4? If not then it doesn't matter. Like I said the put the same type of axle thats in there back in. It is a Chrylser 9.25.
Old Feb 15, 2010 | 10:39 PM
logan horse
It's not 4x4. Ok thanks guys.
Old Feb 15, 2010 | 10:43 PM
Gerehead8's Avatar
Gerehead8
By the way don't pay much more than $500 if it has a few miles on it. Being a 2wd with that much work it isn't worth squat.
