Doing my plenum
Old Feb 20, 2010 | 02:40 AM
lblair04's Avatar
lblair04
Default Doing my plenum
Well, my intake is off and there wasnt a whole lot of oil or baked sludge anywhere. Im in the process of cleaning it all up. I pulled the injectors out, and know I should replace the o-rings. My big question is...there is just a little gunk on the injector (part that goes in the injector boss)....can I just set the injectors in some seafoam to clean them up? I cant find anyone to do one of those sonic cleanings...
Thanks!
Pics will be up later! Not like everyone else hasnt posted a plenum thread, but thought I would just in case I did something different! Im going to cut 1.5" off the runners, at an angle. Also doing the poormans tb intake. Also SCT and plug wires. Will let you know the results!!
Old Feb 20, 2010 | 02:46 AM
dakotas ram's Avatar
dakotas ram
you can get a cheap sonic jewelry cleaner at walmart......
witchhunter.com can clean them...if these arent up your avenue, then yeah, soak em in sumthin or get new ones
Old Feb 20, 2010 | 02:47 AM
dakotas ram
are you gettin a new plenum plate?
Old Feb 20, 2010 | 08:33 AM
lblair04's Avatar
lblair04
I have the hughes plenum kit. This is my DD, so I need something by Monday. I plan on putting it back together on Sunday, after the kegger mod. My truck ran good before, so I would like to just clean them a bit. There isnt a ton of buildup, but I can see they arent completely clean. Also, would NAPA know which o-rings I need, if I just walk in with an injector and say I need o-rings for both ends?
Thanks
Old Feb 20, 2010 | 11:18 AM
dakotas ram
yeah, theyll know which o rings......there only on one end tho... and be sure to oil them before installing to reduce chance of tearing
Old Feb 20, 2010 | 11:27 AM
dakotas ram
if youve got the time, its a good idea to unshroud the injector ports like so
Old Feb 20, 2010 | 11:38 AM
Sheriff420's Avatar
Sheriff420
Carb cleaner and a q-tip ought to do it. That's what I used on mine when i got a bunch of the crap from the inside of the manifold on the tips of the injectors while cleaning it.
Old Feb 20, 2010 | 12:39 PM
J415's Avatar
J415
+1 lube them with motor oil. NOT VASELINE AS SOME MIGHT SUGGEST!!! BTW, am I the only one that has trouble reading Sheriffs post's? I'm way too distracted by his avatar!!!
Old Feb 20, 2010 | 01:08 PM
Gerehead8's Avatar
Gerehead8
They are on both ends of the injector. One that goes into the manifold and one that goes into the fuel rail. When you install them set the o-ring on the opening of the manifold or fuel rail and push the injector down. This worked the best for my when installing the injectors.
Old Feb 20, 2010 | 01:46 PM
dakotas ram
DOH! forgot
