Front hubs
Old Feb 20, 2010 | 10:45 AM
willstruck's Avatar
willstruck
Default Front hubs
I went wheeling, came down hard, and now when I put it in 4wd the hubs don't lock. I know it's pretty easy to tear the vacuum line, I was wondering how you check it for leaks. I was thinking about getting one of those cable hub locker things.
Old Feb 20, 2010 | 11:29 AM
Sheriff420's Avatar
Sheriff420
I would start by making sure that the adjuster on the linkage for the shifter was still where it should be. You should be able to see a wear mark if it moved.
You can see it hanging on the left side of this picture
This is on a gasser, but yours should be similar.
Old Feb 20, 2010 | 12:46 PM
willstruck's Avatar
willstruck
That controls the hubs? I'll check. It goes into low, but since the hubs don't lock it's 2low...
Old Feb 20, 2010 | 01:59 PM
Sheriff420's Avatar
Sheriff420
That controls whether or not the 4x4 will engage all the way. You're probably on the right track in wanting to check the vacuum on the cad, but it wouldn't hurt to make sure the linkage hasn't shifted at all. Hopefully you didn't damage the vacuum motor inside the cad.
Old Feb 20, 2010 | 02:09 PM
zman17's Avatar
zman17
Retired Moderator - RIP
http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Feb 25, 2010 | 10:40 PM
willstruck's Avatar
willstruck
Wow, thanks. I had no idea how the hubs locked. Cool. I have a bunch of other things to fix before I can even drive my truck, so I can't mess with the CAD yet.
