Trans temp. gauge
Old Feb 20, 2010 | 02:33 PM
01greenram's Avatar
01greenram
Default Trans temp. gauge
Im new to dodges and this forum so go easy if this is a stupid question. I want to run the double gauges on the A pilar can i run the tranny temp. gauge on a gas motor does it really matter. like i said go easy
Old Feb 20, 2010 | 02:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Welcome to DF. I'm doing the same thing, and next time I change the tranny fluid(which will be soon because I installed a drain plug, )I will be installing the sending unit in the pan.
Old Feb 20, 2010 | 02:57 PM
01greenram's Avatar
01greenram
ok thanks i know i can know i changing mine real soon i have mudded it a couple good times. so the sending unit goes in the pan of course do i have to drill any holes? i thought about it of course you have to drill holes is it hard to do
jasonw's Avatar
jasonw
Site Moderator
Welcome to the forum.
This subject has been discussed before, but not for a little while. You can try doing a search if ya like, the link to do so is in the black navigation bar right below where it says "Welcome 01greenram" and shows you how many private messages you have.
Otherwise, I'm sure others will chime in here with their input. Many of done this modification, and if you do some pulling or heavy hauling now and then, I've been told it is worth it.
Old Feb 20, 2010 | 03:05 PM
01greenram's Avatar
01greenram
i dont pull or haul stuff but im turning 35's and want to keep an eye on the trans temp. cause i have heard the trannys is these dodge are terrible
Old Feb 20, 2010 | 04:09 PM
zman17's Avatar
zman17
Dude? come on already!
And good luck with those 35's and 3:55 gears. The tranny will be toast in no time. Do a search here about the tranny(46RE) and the tire size.
Old Feb 20, 2010 | 04:44 PM
J415's Avatar
J415
You can definitely install a temp gauge. However, depending who you as, you'll get MANY different answers as to the best location for the sender unit. Welcome to the DF. Hope you stick around.
Old Feb 20, 2010 | 08:32 PM
codyselcamino's Avatar
codyselcamino
I along with many others here have put it in the front servo port, it usually runs about 130-140 but its been below freezing as long as ive had it, I got stuck monday and it got up to 180, I have a pretty big cooler on it too, it really helps
Old Feb 20, 2010 | 09:42 PM
01greenram's Avatar
01greenram
come on about what?? i know about the 3.55 gears as i have done the search so i will be putting 4.56 gears in the rear
