15" rims on an 01?
Old Feb 22, 2010 | 02:40 PM
lord0fsal3m's Avatar
lord0fsal3m
Default 15" rims on an 01?
will 15x8 rims fit on an 01 1500 without rubbing the dual piston calipers or having any other problems?
Old Feb 22, 2010 | 02:45 PM
dakotas ram's Avatar
dakotas ram
prob have to grind a little on your calipers
Old Feb 22, 2010 | 02:46 PM
Twisted Metal's Avatar
Twisted Metal
Double check the back spacing. You will need more backspacing to clear the calipers. Measure from the center hub of the wheel to the edge of the inside wheel lip to get the measurement. IIRC, a 5" backspace is minimum to clear the calipers. If i am wrong I am sure someone will correct me.
