4x4 problem
Old Feb 23, 2010 | 03:03 PM
Maxx_Magnum's Avatar
Maxx_Magnum
you would need to have it running at least long enough to put it in 4x4 because it needs the vacuum to engage the front axles.... but once it's in you should be ok to have it shut off
Old Feb 23, 2010 | 03:04 PM
jamestheron08's Avatar
jamestheron08
mine does this to i replaced the drive shaft and no change i also put it on a lift wile running and it wouldn't do it till i had to brake torque it put a load on it then it started poping trans shop i was at said it was coming from transfer case but I'm broke so it still pops lol
here is a video i made of it turn up your sound real loud to hear
http://www.youtube.com/watch?v=nz4iozlgNBg
Old Feb 24, 2010 | 12:59 AM
KY BIGRAM's Avatar
KY BIGRAM
With an open differential, it will only spin the opposite tire the opposite direction without it running.
Shake the front driveshaft and see if you can notice any slight play.
Old Feb 24, 2010 | 02:56 AM
iwhitne's Avatar
iwhitne
do a search.. replace your from U-joints.. should be around $300ish at the loacl shop.. of you can do it for less than $100 on your own with proper tools and Haynes manual get the loan-a-tool from local APS(auto parts store) to remove the caps
you'll have to pull the front axle as well..fyi
Old Feb 24, 2010 | 11:28 PM
dhvaughan's Avatar
dhvaughan
^ not axle u-joints...
if it only makes this noise in 4wd and not in 2wd, then its NOT going to be axle u-joints, since those turn all the time in both 2wd and 4wd.
the only new motions that come into play in 4wd is the front drive shaft and power through the ring/pinion, and the coupling of the CAD.
Old Feb 24, 2010 | 11:33 PM
rczanstke's Avatar
rczanstke
Originally Posted by rczanstke
The front axle u-joints were just replaced. I'll put it on jack stands as soon as i can. I have to get some money to buy the jacks stands and a new jack. I'll post the results as soon as I do.
