IAC question
Old Feb 22, 2010 | 10:02 PM
MAJohns's Avatar
MAJohns
Default IAC question
hey i need some help here. this is not on a dodge its on a ford but it should work the same. i replace my IAC and now it works great but make a loud *** air sucking noise and vibration. has anyone ever come across this problem?
Old Feb 22, 2010 | 10:08 PM
PurplDodge's Avatar
PurplDodge
That means your IAC is working.
Old Feb 22, 2010 | 10:09 PM
MAJohns's Avatar
MAJohns
ok but its a vibration in the gas pedal and its obnoxiously loud. i have never heard anything like that before.
Old Feb 22, 2010 | 10:11 PM
MAJohns's Avatar
MAJohns
when you give it some gas it gets quiet.
Old Feb 22, 2010 | 10:13 PM
dhvaughan's Avatar
dhvaughan
when you give it gas the throttle plate opens which bypasses the IAC.
you probably have the air filter loose or missing gasket or on wrong or something thats letting all that sound out.
Old Feb 22, 2010 | 10:15 PM
yakkier's Avatar
yakkier
Did you break of rupture your gasket on the throttle body?
Old Feb 22, 2010 | 10:29 PM
MAJohns's Avatar
MAJohns
no i just took the 2 screws out holding on the IAC and swapped them out and its started doing that.
Old Feb 22, 2010 | 10:47 PM
dhvaughan's Avatar
dhvaughan
was there an o-ring on the old one, and did you put o-ring on the new one ?
Old Feb 22, 2010 | 10:51 PM
yakkier's Avatar
yakkier
Eh the Orings usually come off with the old one and the new one comes with a replacement because they dont want you to reuse the old one. Run the engine an unplug the IAC and see if the idle start changing, they might have given you a defective one.
Old Feb 22, 2010 | 11:08 PM
MAJohns's Avatar
MAJohns
yea thats what i am thinking.
