Torque convertor problem?
Old Feb 24, 2010 | 06:58 PM
mbrinegar57's Avatar
mbrinegar57
Default Torque convertor problem?
Ok so lately my transmission is been acting up. its fine just driving normal but if i drive in alot of stop and go traffic the torque convertor will not lock up at all like its supposed to and i drive up a mountain every day and it kills my power. when i get home i can cut it off for like 20 mins and its fine.
Old Feb 24, 2010 | 07:08 PM
PurplDodge's Avatar
PurplDodge
Pressing on the brake pedal will unlock the torque converter.
Here is an easy fix, turn the Overdrive OFF.
Old Feb 24, 2010 | 07:15 PM
mbrinegar57
thats with the overdrive off. usually it will just pull along up the mountain fine. but some days it struggles going 55 or 60 and the trans temp gets up about 190 F its normally 140 F
Old Feb 24, 2010 | 07:21 PM
PurplDodge's Avatar
PurplDodge
Did you check the fluid level?
Old Feb 24, 2010 | 07:23 PM
mbrinegar57
yea its good
Old Feb 24, 2010 | 10:55 PM
mbrinegar57
suggestions? anyone. is my torque convertor going bad?
Old Feb 24, 2010 | 11:41 PM
J415's Avatar
J415
just throwing this out there, but it could be the torque converter clutch solenoid thats going bad. Are you getting any codes?
Old Feb 24, 2010 | 11:52 PM
mbrinegar57
no havent got any codes
