Whats up with my truck????
Old Feb 24, 2010 | 10:33 PM
tinkerinman's Avatar
tinkerinman
and no. it idles the same if its in park drive nuetral or reverse..... sometime the idle picks up a bit and isnt rough at all.... but lot alot. the rough has been more and more today. not in extremety... the same vibration just more regardless of hot or cold....
Old Feb 24, 2010 | 10:34 PM
Dixie Mudslinger's Avatar
Dixie Mudslinger
well if the chain was loose it could have jumped a tooth and it would idle horribly and would cut back
tinkerinman
this problem just started.... the honeycomb in the cat shattered.... took it out.... 02 sensor went out. changed it... now has rought idle....
Old Feb 24, 2010 | 10:35 PM
tinkerinman
i thought that timing would be worse if was loose...
Dixie Mudslinger
does it seem to feel like it jumps when u are stopped at a light?
Old Feb 24, 2010 | 10:37 PM
yakkier's Avatar
yakkier
i'd start with the cheap parts first then work your way up.
tinkerinman
yes. if i barely hold the brake it lerches.....
Old Feb 24, 2010 | 10:38 PM
tinkerinman
replaced wires plugs dist. cap O2 sensor oil and filter cleaned the IAC and the throttle body....
Old Feb 24, 2010 | 10:39 PM
tinkerinman
also checked and fixed and broken vac. lines....
Old Feb 24, 2010 | 10:41 PM
yakkier's Avatar
yakkier
have you reset your PCM ?
