Need thoughts on the Ram Air Intake by Volant..
Old Apr 27, 2005 | 01:17 PM
zeekxxx's Avatar
zeekxxx
Default Need thoughts on the Ram Air Intake by Volant..
http://www.jcwhitney.com/autoparts/S...searchbtn.y=14
This is a scoop system that uses the positive airflow that flows through the grill and gives you a positive pressure in the airbox.
Sounds good. Someone tell me if its crap..
See above link,
thanks
Old Apr 27, 2005 | 02:20 PM
steve05ram360's Avatar
steve05ram360
Default RE: Need thoughts on the Ram Air Intake by Volant..
doesnt look bad at all... however, 2 things to consider... if you ever want to go to a larger filter, your stuck. if the housing is metal of any kind, it will get heat soaked and you wont get the most hp out of it.
I have the K&N and swapped my stock cone for a 7"x9" round filter and found so hp on the upper end with very minimal loss on the low end. I'm always trying to do mods to keep the low end and this one was worth it because I saw hp increase from 2k up.
hope this helps...
