Bad fan clutch?
Old Feb 25, 2010 | 03:03 PM
USAF90's Avatar
USAF90
oh i misunderstood, YES if the clutch didnt "slip" then it would over cool and sound like your taking off at an airport
Old Feb 25, 2010 | 03:28 PM
Sheriff420's Avatar
Sheriff420
I've been wanting some e-fans anyway. But I don't want to spend the big bucks for the perma cool fans. I reckon I need to search to find the best (cheaper) e-fans. with reservoir options to replace mine since they're fitted to the shroud.
Old Feb 25, 2010 | 03:31 PM
yakkier's Avatar
yakkier
Mine has a little bit of play in it but it straight and true when running with no movement. so i dont know how bad it needs to be before you change it out
Yep you're from walton county LMAO!! that's something i would have done after a couple cases of beer and a few shot's of whisky
Originally Posted by USAF90
only one way to find out. rap a nice thick towel around your hand/arm.. then try to stop the fan when the motor is running... seriously
if you CAN stop the fan, then its bad..
EDIT: remember theres gonna be tension on the fan clutch (hard to spin). the only purpose for it is to "slip" when the engine is spinning. otherwise, if it didnt slip, you would have a super loud roaring under the hood. and if it didnt spin at all, obviously you wouldnt cool the engine down enough.
Old Feb 25, 2010 | 04:18 PM
blbikerood's Avatar
blbikerood
Default ewwww
Electric fans would be nice.
Old Feb 25, 2010 | 04:24 PM
USAF90's Avatar
USAF90
thats my next project im thinkin. i wouldnt mind that permacool fan.
Old Feb 26, 2010 | 02:03 PM
Sheriff420's Avatar
Sheriff420
Anyone else have a little bit of wobble in their fan?
Old Feb 26, 2010 | 02:08 PM
95RAM360's Avatar
95RAM360
i had wobble before i replaced mine a few months back.It was roaring as well....my new one has no wobble at all.
Old Feb 26, 2010 | 02:24 PM
blbikerood's Avatar
blbikerood
Default my new one
has no wobble at all either. and the truck runs a ton better and seems to have more get up and go.
Old Feb 26, 2010 | 02:27 PM
Sheriff420's Avatar
Sheriff420
Well my fan doesn't roar and it definitely doesn't overheat, it actually runs pretty cool.
I'm debating whether I should drop 50$ on a new clutch or 250$ish on e-fans.
Old Feb 26, 2010 | 02:29 PM
95RAM360's Avatar
95RAM360
since its really not a problem right now, (no roaring/overheating)........id save for the efans
