Check engine code for Air Charge Sensor
Old Feb 25, 2010 | 03:42 PM
yakkier's Avatar
yakkier
Default Check engine code for Air Charge Sensor
What the hell is an air charge sensor ? autozone said im pulling a code for it and they have a replacement but i dont know what the hell it is and the truck is running fine so do i actually need to replace it ?
Old Feb 25, 2010 | 03:57 PM
PurplDodge's Avatar
PurplDodge
It is also called the AIT (Air Intake Temp.) sensor on our trucks. It monitors the obvious, the temperature of the air coming into the intake manifold. The PCM uses this sensor along with the coolant temperature sensor, MAP sensor, and the O2 sensors to determine the Air/Fuel ratio.
It sticks out the passenger side of the intake manifold right behind the alternator.
Old Feb 25, 2010 | 04:00 PM
yakkier's Avatar
yakkier
How essential is it ?
Old Feb 25, 2010 | 04:10 PM
PurplDodge's Avatar
PurplDodge
I think it is pretty essential. But before you replace it, I'd check the resistance of the sensor (per Haynes manual) and clean it. Reset computer and see if the code comes back.
Old Feb 25, 2010 | 05:06 PM
Gerehead8's Avatar
Gerehead8
What was the exact code number. I can look it up i my service manual if you want. 23 is the IAT.
Old Feb 25, 2010 | 05:18 PM
yakkier's Avatar
yakkier
I dont know the number, i was in the area when it came on and i had to stop by autozone to pick up a part i had order ealier this week so i just had them check it there. The light is off right now but has been poping on an off all day
Old Feb 25, 2010 | 05:22 PM
Gerehead8's Avatar
Gerehead8
If it is the IAT the book says that the check engine light should illuminate during operation if it gets a bad signal (voltage to high or low).
Old Feb 25, 2010 | 05:26 PM
yakkier's Avatar
yakkier
thinking it might be a voltage issue then, the wire's look fine. I will go check the voltage tonight when i get home
Old Feb 25, 2010 | 05:35 PM
Gerehead8's Avatar
Gerehead8
All the computer reads are the changes in voltage from the sensor. If the sensor is bad or going bad it would throw a code.
