multipule issues...
I HATE TRANSMISSIONS! the one thing in a vehicle, i dont know any substantial info on...
thats what i told them when i took it for a ride, i know my truck like no onther... so i told them,,, the trans linkage needs to be adjusted... but will that being messed up, keep it from going into overdrvie?
the truck runnin rough is probably just some moisture,,, it got better as i drove... keep in mind the truck sat in a shop for about a month, so i dont dought it... but the vac lines are all hooked and good... i checked that myself...
Dude my truck sat for over a year outside in ran and snow with no coolers hooked up and no motor attached to the trans. I also hosed the engine bay down and sprayed the hell outta everything including the tranny. I didn't have any problems at all. I don't see moisture being an issue. They didn't do something right
thats what im figureing... but the only thing thats tellin me it is just something in the motor,,, you put the truck in park, or neutral, and it still does it....
and the tc i have no idea if it was changed, i know the one i had was brand new, and they either used that same one or gave me another new one.... i dont know,
but i cant really take it anywhere else cause all the work thats being done is warrentte work, and i dont have the money to have them do it out of my pocket
If that's the case then i would get the transmission back and have it " fall off a truck " and break the freaking thing into a million pieces and then maybe they will give you a new one.
Or just simply say if they dont get it fixed you want your money back and if they tell you to **** off then mention a lawyer.
Transmission/engine's will raise an eyebrow in court because they are a higher ticket item, parts wont get you anywhere though.
This is why i dont like to bring my stuff to a shop , Because it seems to me that they could do a little tweak here a little tweak there on your vehicle and then they give you the runaround and have a repeat customer throwing more money at it, not saying all shops are like that but im sure it happens.
![Icon No](https://dodgeforum.com/forum/images/smilies/icon_no.gif)
