Fog light connectors.
Old Feb 26, 2010 | 02:13 AM
JackJ's Avatar
JackJ
Default Fog light connectors.
Does any one have some pictures of them NOT connected to the lights. I have a set of $40 "Off Road" lights from HF and want to connect them to my fog light harness in place of the crappy ones I have and I suck a wiring. I cant get the lights out due to a stripped something, and before I start pullin crap apart I wanna make sure I don't need to get different connectors.
Old Feb 26, 2010 | 08:56 AM
bardram's Avatar
bardram
I would seriously doubt that any aftermarket light is going to plug right in to the stock clip. It would be very easy to splice the wires though.
Old Feb 26, 2010 | 10:22 AM
Cheat's Avatar
Cheat
What ever you do, DO NOT use the factory wiring to run 2 aftermarket fog lights, Youll burn up a light switch in no time, Use a relay. using these pins:
30- positive from bat. dont forget to fuse with a 15 amp-20 amp fuse.
85- ground to frame or bat.
86- pos from old fog light conector Dosnt matter which side
87- Positive out to aftermarket fogs.
ground your lights to frame or battery. Then there is less load and less chance of a cab fire because of dodges cheap wiring.
Thanks,
Cheat.
Old Feb 26, 2010 | 11:16 AM
ET RAM's Avatar
ET RAM
This may help.
Fog Lights
Old Feb 26, 2010 | 11:51 AM
Maxx_Magnum's Avatar
Maxx_Magnum
Originally Posted by ET RAM
This may help.
Fog Lights
good link
here's the diagram from there... This is pretty much how I wired my rollbar lights, except I used a lighted toggle switch, and I ran a separate power wire to each light from pins 87 and 87A
