broke screw
I just did my steering box and straightened my steering wheel the other day, turned out pretty good. I over tightened the box a little to much you can deff tell when you do it, i backed it off and what a night and day difference, and if i'd known that straightening your steering wheel was that easy i woulda did it a long time ago.
Don't worry about it then. Pull the distributor to do it right, and not mess anything else up.
IF you remove the distributor, MARK BOTH THE BASE AND ROTOR position exactly. you've got to get it back in the exact same position or it won't run and you'll have a much bigger problem.
