Quick and easy mods or tweaks??
He has a point. I set fire to my 1996 when I installed a fuel catalyst in line fuel filter and did not wait for the gas to evaporate (forgot to purge).
hence why I put on a fastman TB, and new injectors (the MSD came later because I found it when i thought I left it in my old house).
Got the truck running and even survived a trip from OK to CA....thru the dessert!!!
I dont have the best looking truck... Trust me. Haha! I could careless if it is fast... I use my truck to haul things... So it needs power. Im fixing to overhaul the engine so if im going to change things it will be when I do that...
good. you might want to check out these:
http://www.harlandsharp.com/dodge_magnum.htm
These are perfect for those who want extra hauling power. I almost got them a year ago because i move so much and pack my truck heavy. But the truck is still under warranty. 2012 will be a great year. But I am currently doing research. I know I can put on headers and not void the warranty. But I would rather just wait until I can do a few more things.
Comparing their lift to overpriced "Computer friendly" camshafts is about the same. Plus they are direct bolt ons!!!
Right now, the plan is this:
Harland sharp roller rockers
Hughes F-1 intake
aftermarket ignition specifically for 4x4s (looking at mallory, but the MSD I swapped out from my thirdgen camaro worked perfect)
shorty headers
SCT from hughes with all 3 of their programs.
I was thinking of just putting on a NOVI, but I don't want to have to replace my tranny along with that upgrade.
Expect your FIRST tranny to go at 70K if you are running bigger tires and do not have the OFF ROAD package with taller gears.
Hughes F-1 intake
shorty headers
No. I not running really big tires... My engine right now has almost 300k miles... Im shootin b4 the summer ill be overhauling it... So I wana be ready for what im going to do with it... I want to find....
MSD ignition...
Hughes Airgap...
Fastman TB...
Fuel rails I am going to make as well as re doing the fuel lines themselves....
Yall should see the condition I got this truck... It was horrible! Ill post pics tmrw when I do my DIY on "VOLTAGE REGULATOR BYPASS"... Its been through some **** in 300k miles! haha!
MSD ignition...
Hughes Airgap...
Fastman TB...
dude,if you are gonna overhaul the motor, get a better cam setup. i have a few boltons and i am not even close to being satisfied with the power. got a underdrive pulley ordered and gonna get a different intake too. and i know i still wont be satisfied.
just my opinion.
just my opinion.
Im not getting a different truck... This one works just finae and is well worth the 1k I paid for it.... HAHA! That was a couple of years ago... Blue book is 2700. BUt im just tryin to put a little into this thing so I know it takes care of me a bit down the road. It is an investment and should be treated as such...
